Gordon
Would you know what the torque specs would be for a coyote engine and QuickTime bell housing?
1. Fly wheel to engine and do I need locktite or sealant?
2. Pressure plate to flywheel?
3. Bell housing to engine?
4. Tremec to bell housing
Thanks for your help..
Pro FFR Builder and Moderator
The flywheel should be 65# use sealer on the threads
Clutch plate- 25#
bell- 38#
trans to bell- 35#
Gordan
Thanks for the reply, I did get a response also today from FFR Tech department, they thought the flywheel should be set at 177 FT/IN plus 60 degrees. I don't have a way to do the Torque degree but could buy one if you think I need it. 177 FT/IN equals 14.75 Ft/LB that sounds low but I'm not sure what happen after you torque to plus 60 degrees. What do you think??
Happy New year
That id for the torque to yeild bolts the factory use. I recommend using ARP. They have an actual torque rating.
