Need some help with a Gen 2 coyote Build. I have a 1968 F100 with a Gen 2 and the issue I have is my motor will not turn over or crank. I get power to the starter and it just clicks. I have dropped the starter, bench tested, and had the local Advanced Auto test as well and it is good. I have removed all ground and sanded each down to bare metal and reconnected. I also showing (12.4) at the ground of the fuse box. Any help would be beneficial. I did get it to start during initial setup. And that was with a power wire from ignition to starter. Tried to go back and wire during initial setup but it kept burning up HAAT B 10 Amp mini fuse. Wired up to its current setup and just get a click at the starter.
