1 - 13 of 13 Posts
I did a quick search and could not really find anthing on this. I have access to an IRS set up from a Merc Cougar. Is it the same as the T bird SC? If not, should I steer clear of it or can I use it?
This is the list of donor vehicles from the FFR page on IRS:
Donor Vehicles
1989-1997 Thunderbird Super Coupe (All Posi-traction)
1992-1997 Thunderbird V-8 models with rear disc brakes (some posi-traction)
1992-1997 Lincoln Mark VIII (All aluminum carrier, most non-posi-traction)
1989-1992 Mercury Cougar XR-7, supercharged V-6 (All posi-traction)
1993-1997 Mercury Cougar V-8 with rear disc brakes (some posi-traction), after 94 all Cougars were called XR-7’s
Darren
It depends on the year. Check the FFR website, they specify which ones will work.
Chris
I used the rear from an '89 Cougar XR7. The XR7 uses the same rear as a TBird SC
Thanks guys. The Cougar is in my Dad's salvage yard so the price of the rear end will be right. I will have to check the year model and see if it is posi trac or not.
Don't trust just the year for the posi.
Do the wheel test to see if it really does.
I hate to bug you guys but I will admit I am a GM guy with the exception of a 289 67 Cougar I built 25 years ago.
I called my Dad about the Cougar in his salvage yard and he said it was a Supercharged V6 5 speed car. The engine and trans are gone but the IRS is still there. My guess is it is a posi set up with some decent gears. He also has at least one more cougar and 2 or 3 T birds. I will be there this weekend to do some research. Any advise on what and where I should be looking on the IRS to help Identify it or will the VIN # help me any?
One last ?. I e mailed FFR but have not heard from them. How much does it add to your kit to have it prepared for an IRS? I found the price on the form but I am assuming this includes the IRS set up which I do not think I will need.
Thanks for your help on this.
The IRS option does not include the carrier, axles or spindles/brakes. Includes subframe, upper/lower control arms, shock/springs, axles only(no cv joints).
Discussion Starter · #10 ·
So even if I was using the IRS set up, I am still looking at an additional $2500.00? If this is true, for budget purposes, I will have to stick with the solid axle.
$1950 for standard width option, $2450 for pin drive option plus the cost of the donor parts which usally is $200+. Then the parts you would want to replace like calipers, rotors, redrilling hubs for 5 on 4 1/2" etc, ect.
Solid axle is much cheaper, but the IRS is real nice and resale you wont loose.
Convincor is correct.
I did the IRS and costs for doing were as follows. The rear makes it more authentic, rides better, handels better, but costs more. It's a choice we all make but this was a must for me.
1). FFR IRS option free due to superbowl discount.
2). Complete IRS from wrecking yard. $250.
30. Replaced all rubber bushings with urethane website vendor (cont think of his name but others can chime in) also new hub bearings and re drilled hubs to 4.5" total $300.
3). Rebuilt calipers $70 ea. total $140.
4). New rotors $80.
5). 1 new outter bearing for diff ($14) and both axle seals ($20) total $34.
6). The gears (3.27:1)other bearings and clutch discs did not need replacement.
Total rear end cost including brakes was $804. Will I get it back if I sell, probably yes. Would I do it again, yes.
1 - 13 of 13 Posts
