Is it ok to wire the 14 ga purple wires directly through the clutch safety switch or do I need to use a relay? The Autowire instructions seem to suggest wiring straight through the switch with no relay. I did some searches and saw someone suggested using a relay b/c the load is too heavy and the switch will eventually die. How are you guys doing this? I bought an automotive relay at radio shack but wanted to check first before figuring out how to wire it. Will the relay lower the amperage too much? Thanks.
Raul
Raul
