FFCobra Captain
Any suggestions on what I should use to power the cooling fan?
Can I splice the wire that was the power for the fog lamps right into one of the unused fusebox wires and use that for power?
I'm going to use a thermo. switch, so I don't need to connect it to a toggle switch.
I used the fog lamp circuit and it's working fine. I chose not to use a thermostat, so I'm not sure what effect that would have.
Hey Dan,
I went to your web site and then in a few seconds a car start sound came on. :D Is your engine running now? I like that sound bite, can you e-mail it? If so, [email protected] Thanks.
I still say the fan should be triggered by the VSS switch, when the car slows down. It would take some doing, but makes sense. (to me)
Super Moderator
Make sure you use a fan relay to prevent burning out the fuse, or melting the wire. Most fans draw 25A.
2FAST
Sr FFR builder
Ditto 2fast. Your fan tends to draw a bit of juice. You would be wise to run a relay. I used the relay / manifold switch from www.hotronicsproducts.com Very cool setup and easy to install. Reasonable in price too.
I also bought their cool down timer that allows the fan to run from 2 to 4 minutes (adjustable) after you turn the car off. It also provides for wiring to manually stop it.
Hope this helps.
I connected a pilot light on my dash to let me know when it's running....the only problem is the faster I drive the brighter the light gets, because the fan acts like a generator as you drive faster.
I am replacing the relay with a double pole to prevent fan from turning on the indicator light in the generator mode.
Most definitly use a T- stat control. One moment of forgetfulness and the car overheats.
I had this happen...sitting with the engine running and everyone saying this car looks cool....then coolant all over the driveway.
