So I just changed out the Factory five fan to a flex a Lite 3000 cfm fan, Shortly after starting to drive I smelled something new, not wires burning but pungent, thinking that well maybe it’s paint, well the temp kept going north up to 230 before I got to stop. Coolant boiled over but I hopefully didn’t blow a head gasket , got it home and the fan works if I run it to the battery.
Looked at the fusebox and saw this.
What could’ve happened? If I had reversed the wires on the fan wouldn’t the fuse just blow? I checked the Ron Francis diagrams an Black is ground and blue is positive, that’s how I wired the new fan. Any ideas?
Pro FFR Builder and Moderator
Need to add a 30 amp relay and 30 amp breaker to the circuit.
Discussion Starter #3
Thanks Gordon, the specs on the new fan say 18.5 amp draw, so how much different is that from the factory five supplied fan ? Factory five says theirs draws 19 amps and pulls 2170 cfm. Like I said everything was working before the swap and nothing else changed.
We always add additional relays just for the fans. The standard RF harness does not have enough redundancy.
Discussion Starter #5
Upon further review, I’m the fool who possibly caused it to fry! I crossed up the plug wires at the fan! Why it just didn’t run backwards is an interesting question. I’m not as perfect as I thought.😂
