Really confused about the PASSENGER side aluminum that rests on the radiator and matches the contour of the body. On the multiple pieces I have received from FFR the "flange" is bent outwards. On the driver side the flange is bent inwards. Does that make sense? I would think on both pieces the flange should be pointed inwards. This is a MKII not that should matter. Please help before I try calling FFR again.
tim
Sounds like you have two driver sides. Call FFR.
Don
That's what has me all messed up. The kit came with two flanges bent the same way, one flange was a lot wider at the front than the other. I called FFR they sent a second piece with a wide flange, that to me is the driver piece. I got help again at FFR and another piece showed up today with the flange pointed the same way as all the others but this one had a small flange like one that came with the kit. What I think I have is two driver pieces bent correctly and two passenger pieces bent incorrectly... unless I am missing something...that's what I need you guys for.
tim
tim
Tim I wanted two pieces with the wide flange when I call FFR I ask for one that was not bent and did that myself.
