1 - 20 of 21 Posts
After alot of research and personal choice, I went with Chris Richards Mass-Flo system, the quality is flawless, the look vintage, it has exceeded my expectations and my budget, it was a diamond in the rugh and I just can't stop myself, I have all the parts and each day a little more work gets done. Thanks Chris.
Sly
http://i121.photobucket.com/albums/o212/ffr1422k/cobra012607013.jpg[/IMG]
[ January 27, 2007, 12:19 AM: Message edited by: Slytherin ]
Discussion Starter · #2 ·
Looks good. What did you cover the injector wires with?
07018.jpg[/IMG]
Discussion Starter · #10 ·
Discussion Starter · #11 ·
Discussion Starter · #12 ·
Discussion Starter · #13 ·
Discussion Starter · #14 ·
Discussion Starter · #15 ·
Slytherin,
Very nice! How did you connect that FE puke tank to your 331? I would like to do that too.
Chris
Discussion Starter · #17 ·
Thanks Chris,
follow the angle of the mount that is on the tank and mount plate to 45 degree thermostat housing from Summit and notched plate arround housing, I have a great builder in Fairfield that can make anything work.
Sly
[ April 21, 2007, 03:12 PM: Message edited by: Slytherin ]
Discussion Starter · #18 ·
Looks great, what a difference. Those 427 valve covers look pretty sharp on the 302!
If you dont mind me asking, where did you purchase your expansion tank?? That is the style i want, but i have not been able to find it with the passenger side upper radiator hose hook up.
thanks
Originally posted by Slytherin:
Thanks Chris,
I used a 3/16 plate follow the angle of the mount that is on the tank and mount plate to 45 degree thermostat housing from Summit and notched plate arround housing and use new bolts that are 1/4 in. longer.
I am planning on using an FE puke tank as well but I'm not following exactly what you did. Could you explain in a little more detail or differently?
1 - 20 of 21 Posts
