Code #96 comes up as a Fuel Pump secondary circuit failure. Is this the inertia switch? I made sure the red button was pushed in and tried again and nothing.
Mike O.
3 Generations on a MkIII
What computer are you running? On a Mustang Mustang EEC-IV a 96 - Fuel pump secondary circuit failure - the problem is battery to PCM (Powertrain Control Module)
HTH.
Sorry should of specified. A9L comuter running the Mass Flo system.
I unplugged the inertia switch an stuck a test light in the terminal comming from the relay. It comes on as soon s you turn the key. godes back out then flashes and stays off.
The relay clicks a couple of times and then stops. I tried one of the other relays and it does the same thing.
Mike O.
Wow. You got me. I was gonna' say to chcek the ground cable from the tank to frame... but now..
Bypass the entire inertia switch. Start to eliminate variables.
Mike,
Searched Fuel Pump secondary circuit failure and came up with this:
Fuel pump secondary circuit failure. The EEC senses infinite resistance to ground from the fuel pump on the Fuel Pump Monitor circuit.
Possible Causes:
> Fuel pump secondary circuit short to power.
> Fuel pump relay contacts always closed.
> Open in FPM circuit between EEC and connection to the power-to-pump circuit.
> Left O2 short to power.
> Damaged Computer.
Kenny
Mike. Your PM box is full. Did you trace down the problem?
