Vegasjack
I am beginning to apply cockpit insulation throughout the cockpit. By recommendation I ordered "EZ Cool Insulation." When I did a flame test on it with a simple match, it ignited rather easy, burned hot with a lot of soot. My bad, I should have read up on it before buying. Fortunately I did not buy a lot of it. Having experience with fire before, I have no desire to use material of such flammable properties. I realize many builders used EZ Cool, which is their choice. I have not heard of any others having an issue with it.
So, has anyone else used a good insulation/sound deadening material they recommend? I do realize most will ignite with enough heat-I get that. But I don't want something that ignites with a spark and burns so rapidly that I may not be able to get out of car or be rescued in event of a fire.
I am looking at going with Dynamat, which in itself will burn, but extremely hard to ignite and burns very slowing. Does it make a difference? To me it does.
Any suggestions of a good flame "Resistant" insulation?
Thanks in advance.
Hi VegasJack,
I respect the fact that you had prior experience with fire, and I'm glad that you were able to survive what I can only imagine to be a scary situation.
But I wonder if the insulation is what you should be concerned with. Have you put a match to the carpet too? Did it burn? Installed correctly, the insulation should have aluminum panel on one side, and the carpet on the other side of it. I can't imagine how it would be the source of flame.
Maybe someone will have an answer. But as a satisfied user of the EZ Cool Insulation as an open insulator without carpet, I can only say proceed with what you have. :grin2: Carry on. Dave
I used Dynamat. More expensive, but better quality. Cheaper insulation may be okay for horizontal installation, but vertically has been known to droop in a hot environment. Just my opinion.
I used Dynamat. If you go this route, you'll need two boxes (each with nine 18" x 32" sheets) to cover the cockpit, firewall, & trunk.
I have used Dynamat, HushMat and Kilmat.
HushMat is a lot cheaper than Dynamat and appears to be the same product.
I have used KilMat on the last three cars. I did a Cobra interior and trunk with 80 mil Kilmat for $120 delivered last spring.
50 mil Dynamat was about $230.
I far as I can tell all three products are the same quality.
Google KilMat and read the reviews. Also search You Tube. A guy did a bunch of test on all three brands.
I like the KilMat better
After some research I just bought some Noico 80 mil. It was $65 for 36 sq feet on Amazon prime. I haven't installed it you, but based on some reviews and the look and feel of it, I think it will work fine.
GUYS
Had to chime in, USE GLOVES when applying insulation such as Fatmat or Dynamat. The cut foil edges can be really, REALLY sharp.
Happy building!
