1 - 2 of 2 Posts
· FFCobra Fanatic
I have Cobra SN95 brakes in the front and IRS stock Thunderbird brakes in the rear. I am planning on using 17" x 9 Cobra R wheels with 24" offset all around. On another post someone said if you are using SN95 brakes make sure to let the wheel company know, so thay can send the wheel with the correct backspacing. Is it a different backspacing on the mustand II front spindles? Will the wheels I have picked out work?
Ron
· FFCobra Craftsman
5.95" back space is correct for SN95 spindles. this also assumes the IFS comp brackets have been installed. Im not sure about the rears if there the standard drum widht or the wider disc.
The rear disc car take the 6.42 rear back space.
Phil
1 - 2 of 2 Posts
