1 - 15 of 15 Posts
Do I need to use a thread sealant on the brass fittings that screw into the CNC master cylinder??
Thanks, Stan
Stan I used teflon tape.
drmcat
Brake fittings seal at the flare, not the brass fittings, so no sealant is needed.
mike
There should have been intructions inside the master cylinder about this issue, was in mine but at the office not anywhere ner the Snake-pit.
What Country You From?
Yes... The brass that screws into the CNC master cylinder calls for Loc-Tite. I don't have the actual sheet in front of me, but I remember it saying to "seal fittings with Loc-Tite"....or something like that.
The instructions that came with mine said to use a quality thread sealant, and recommended Loc-Tite brand teflon paste. That's what I used.
Loc-Tite is a brand name. They make a lot of products besides thread lockers. A thread locker will not always provide a good seal.
Be very carefull about tightening the brass fittings. If you crack the alum housing, it's your won fault and you have to buy another one.
Thanks Guys!!!!!!!!
Stan
Originally posted by Stanley W:
Thanks Guys!!!!!!!!
Stan
Wow, you're sure easy to please. You got 6 answer/opinions, some contradictory, and no one even bothered to ask whether you were talking about pipe thread fittings or flare fittings.
Originally posted by Oldguy668:
</font><blockquote>quote:</font><hr />Originally posted by Stanley W:
Thanks Guys!!!!!!!!
Stan
Wow, you're sure easy to please. You got 6 answer/opinions, some contradictory, and no one even bothered to ask whether you were talking about pipe thread fittings or flare fittings. </font>[/QUOTE]There's only one fitting that screws into the MC. It's a pipe thread.
GONG!...Wrong answer. My master cylinders have 37 degree female flares in them. Not a pipe thread in sight.
Answered 1st, I was not even thinking! Good point Joe.
Hi Stan,
The CNC masters have a 1/8 npt thread. I use teflon thread paste on the CNC's.
Wilwood & Tilton use 3/8 x 24 with crush washers.
I never use or sell teflon tape....
How did that happen? Did you order them special that way?
1 - 15 of 15 Posts
