1 - 10 of 10 Posts
Ok I know its been an issue for some but, my clutch pedal wont engage because it hits the 3/4in tube. Whats the best solution for this? cut the tube and attach a new section on the outside of the tube as some have done? want to get some feed back before I cut the tube. I am using the complete kit wilwood pedal set. thanks- Andy
I notched my tube to match the angle of the travel of the clutch pedal. I did not cut all of the way through but I came close. Most will say that is good enough but I had a welder sitting there so I piggy backed a 3/4" tube onto the outside. I also added a bolt to the pedal box to act as a stop for the clutch.
Ben
I cut top bottom and inside, leaving the outside of the tube. (Dremel tool) I then used square stock to make a solid plug inside each end. Another piece of square stock on the outside, and it is all bolted together.
I had the same issue to deal with. My solution developed from a different perspective. I assumed the frame was correct and the clutch pedal was wrong.
So, I designed an alternate shape for the clutch pedal and machined it out of aluminum. It works perfectly, will never break and look pretty nice too.
Out of Time
After upgrading the cast pedal assembly to the forged, and attempting to use the 3/4" master (long throw), I had the same problem with my clutch pedal (hydraulic) hitting the frame.
I then changed to 1 1/8" master and the corresponding reduction in pedal throw would have rendered that cut unnecessary.
thanks guys Im gonna try to mess with it tonight
I had the same problem with my Wilwood paddle box and Clutch arm hitting the 3/4" frame. I did a lot of thinking on this as to what I was going to do to fix this problem. One thing that I did was the same as HIRISC had done I went to a hydraulic Clutch. With a 7/8" slave and a 1 1/8" Master hoping that the amount of fluid being pushed would solve the problem? Still I notch the frame as well. I have added a link to photobucket If you like check it out see if this helps. Hope the link works. Good luck.
Ed.
Pictures by BULLITT428 - Photobucket
Discussion Starter · #10 ·
thanks guys I notched out a section of the frame and the clutch engages good now, thanks for the help!!!
1 - 10 of 10 Posts
