Status
Not open for further replies.
1 - 3 of 3 Posts
I've got the clutch cable in but can't figure a good place to bolt the support. Any Help?
Ben
On the timing chain cover there is a block off plate for a mechanical fuel pump. I removed one of theses bolts that hold the block off plate and mounted the clutch cable hold down to it, fits fine.
Actually, if it's a EFI motor or newer timing cover, there won't be a block off plate. But if there is, use it...
1 - 3 of 3 Posts
Status
