1 - 2 of 2 Posts
The clutch cable kits that are sold with the clutch quadrants are they compatible with the cobra set up as they are sold for mustangs.
Does anyone have photos of a new clutch quadrant kit set up on the cobra? How easey are they to install? Is there anything that I should look out for when installing?
I'm not sure what you mean about "clutch cable kits" for the clutch quadrants. The quadrants supplied by vendors on the forum replace the plastic units from the donor clutch pedal assembly. You can use a standard clutch cable or get an adjustable one from Ford Motor Sports.
The quadrant itself is quite easy to install. Just remove the old one with the springs and put on the new. You may need some washers to space it on the shaft but other than that no big deal.
1 - 2 of 2 Posts
