Guys,
Is there supposed to be some sort of retaining clip holding the clutch cable housing where it goes thru the bellhousing? I didn't take my donor apart, but I think I remember seeing one on an exploded drawing in my Chiltons for the Mustang.
Is there one needed? If so, what kind?
TIA,
Chris.
It is a U shaped clip with a rounded flange perpendicular to the U (best description I can come up with). I got mine from a Ford dealer.
Thanks Mark,
I'll get one from the local guys if I can.
CW
Yep there is a clip. Mark described it pretty well!
Living Large
Chris,
I have a few extras I can mail you a couple if you can't find them.
Cheers,
Trent
I used a small worm gear clamp. Works fine.
Thanks everyone for the speedy help as always.
Trent, thanks for your generous offer, I, hopefully can find one locally so you don't have to go to that trouble.
Chris.
You really don't need it unless you're using the stock cable and quadrant set up. And even then I'm not so sure you need it.
However, just do like Dave said and use a standard hose clamp.
