1 - 11 of 11 Posts
Shade Tree Mechanic
Did a search on "cleaning silicone aluminum" and turned up nothing? I was wondering the best method for cleaning the silicone off my panels when it's dry? I tried a Scotch Brite and WD-40 which eventually works but is real slow. I read some posts that said to let it dry then peel it off, but I'm thinking it may be better to use a rag slightly dampened with Acetone when it's still soft?
Shade Tree Mechanic
Brake Cleaner shoulda known, that stuff cleans just about everything in the known universe
The best solvent for UNCURED silicone is denatured alcohol. There really isn't a solvent for cured silicone, but it will come off with mechanical abrasion. Best bet is to clean as you go with the denatured alcohol.
Shade Tree Mechanic
Thanks Joe.
section 8
Carb cleaner, Bob
Over Engineerer
Beleive it or not, but I have the best luck just rubbing it off with my fingers - kinda like an eraser.
Good old fashion...Mineral Spirits!
Laquer thinner here. No matter what is used it takes some amount of rubbing. In certain spots of my build I took extra care to remove(rag+laquer thinner) uncured silicone on certain panels since I knew it would need to be removed in the end.
1 - 11 of 11 Posts
