1 - 3 of 3 Posts
Due to declining health issues , I am selling my gtm project. It was being done as a high end , track capable build, so parts where upgraded. It is currently set up for an LS376 - (engine sold) - with an audi tdi custom built transaxle, 6 speed , ( by GBox) os gekken lsd, quartermaster carbon/carbon clutch. It was built to handle the higher hp/ torque and to last under race conditions, track days, heavy duty street use etc.
Here is a brief list of some of mods / parts etc. -- please note some of the parts are also being listed seperately ( would much rather sell off everything,
including spares, shop supplies for the build etc., even some of the tools as a package deal - 50k.)
mods - body widened front an rear , functional roof scoop, custom carbon fiber louvers / vents .
ffr carbon fiber front splitter, side skirts,
stock corvette brakes or custom Wilwood 6 piston package with dpi recirculation system on fronts
Apr Carbon fiber rear wing - rear hatch modified so wing does not have to be removed to open/ close- gen 2 style.
Battery - raised bracketry so insulated cooling lines run under tray.
Agm power steering installed , mr2 sypder pmp , Ian's controller
ffr tie rod kit
new radiator shield/ fans
Shanes ac plenum mod, blower motor relocation kit
Adjustable seat rails on both seats
corvette seat belts
Harness Bar - for mounting race belts
Overhead console / gauges
Custom - leather for seat inserts, dash center section amd covering overhead console
Russ Thompsons Skid Plates
all aluminum panels are powder coated - silver vein with clear. most are pre fitted/ drilled ready for final installation
Engine bay -
Ls2 / Ls3 wiring harness , custom billet computer bracket - wires re routed / bundled for gtm (if you use and ls3 or 2 you can use as it is - using an ls1/6 you will need to change
Pfadt Motor mounts
Kooks ceramic coated exhaust system ( also avail separately)
Custom Billet transaxle mounts
Transaxle - 6 speed - with OS Gekken limited slip diff, rem micropolished and cryotreated
spare open diff
pump and setrab cooler
Isis 3 cell wiring system
car was go karted and then the project got put on hold
1 - 3 of 3 Posts
