The assembly manaul says the charge indicator light and resistor are necessary to complete the battery charge circuit. I'm using the stock 93' gauges for the dash but am not using the pod as it won't fit there with the A/C/heater box.
#1. Question is; the back of the pod plastic wiring sheet has an is stamped "amp" where the front of the dash battery icon light is. Is this for the amp meter and is this the "charge indicator light"?
#2. Where is the resistor ? Do i use the mustang one or splice in another and which ?
Paul
Paul
