I'm finally getting the ball rolling to do my manual to power steering change. I will be using a reman 93 Fox rack and pump from Napa. I got the hoses and rack extenders from Breeze Automotive, but not sure if I will need the extenders
363409
. I still need the correct steering shaft. Will my current upper arms allow me to get enough caster? (Also using 94 spindles).
Too Cheap to paint!
Unless you are going for a ton of caster, yes as Gordon says.
I relocated the upper shock mount, so the shock assy stays center in the upper arm with 6 degrees caster
I did this conversion on my Mk 1.5 and am running 7.5° caster. In order to avoid interference between the upper front arms and the coil over, I made a couple of changes. On my car the frame points where the control arm bolts (marked in green) go are slotted and I rotated the whole assembly to get maximum caster without changing the arm lengths. I also moved the rear spacer (marked in red) for the upper shock mounts so that both spacers were to the front. Even with 7.5° caster, I still find the steering wheel centering a bit less than I would like but in all the changeover dramatically improved drive ability of the car.
