ANYONE HAVE INFO REGARDING A PREFAB CONSOLE TO MOUNT A STEREO IN. I SAW ONE HERE A FEW MONTHS AGO AND I NEED TO ORDER
I used a standard underdash black plastic housing (mounted upside down to the tunnel). These are designed so the stereo can be put in it right side up (as if you were mounting hanging under the dash, or upside down to the console (the tunnel in the Cobra). Available at almost any place that sells car stereos. cost about $15. Stereo unit slides in and locks in place. Easy to install, takes about 2 minutes (after you get all the wiring done.
Check with Breeze or Finishline...one or both have these consoles (aluminum).....
I made mine out of 1/4" plywood....then covered with matching carpet.
Sr FFR builder
I bought the console from tri-states. But I only used the front piece (which is the most important.) I replaced the sides with steel panels to mount the speakers to. Also, I mad the panels taller to mate with the dash filler that Mike Everson sells here:
HTH,
