Hey guys. I bought a new Ford Racing X302 small block (306 ci), and dropped it in the car a few weeks ago. I then bought and installed an Edelbrock Performer RPM Airgap manifold. Next question was which carb. Ford Racing's website has specs for the engine at 340 HP "with a Holley 650". However, the data sheet that came with the engine simply said "Holley 600", but no other details or guidance.
Holley's online configurator recommends a 600 if the engine is "mildly modified" or a 650 if the engine is "highly modified", the main difference being whether it's got aftermarket heads or not. Although they're only 170's, it does, so I'm leaning towards a 650. Also, based on the recommendation of the configurator, I decided on a double-pumper rather than vacuum, since the car is light and i like quick throttle response.
The sales guy said either would do, but I'd be almost at the limit of what a 600 could support, so I'd be better off with a 650 in case of future upgrades. I also read bunch of blogs and stuff, and folks seem to be split about 50/50, but they are usually talking about much heavier cars.
Although this will be predominantly a weekend car for the street, I hope to get some track days in occasionally. Also, not sure if it matters, but I live at 4,000 ft.
I'd like to get your feedback and/or experience on this.
· Pro FFR Builder and Moderator
Holley pro series 650 or quickfuel 650 would work really well.
Holley...
650DP or 750 vac sec...personally given the low weight of these cars, vac sec is not necessary so I would lean towards a 650 double pumper.
:rolingtire:let the good Times Roll
I will offer the following:
1) Go with a db carb and stay away from vac secondaries since you have a dual plane manifold and a light car.
2) You might take a look at a Holley dp 600 cfm carb (JEGS has them) I have one on my old auto-x corvette with a 355 motor and it works fine.
3) The Holley HP pro series carb, 650 CFM is a race carb that comes with a milled choke horn and works great for an auto-x or track car. I have one on my 402-Roush motor after removing 760 street avenger that came with the motor. It is cold natured and tends to foul plugs but that may be the cam. I think you will be happier with a the 600 dp that has a choke on it due to your location. The neat thing about Holley carbs is you can change jets fairly easily if the altitude is a problem.
This has been my experience over the years:
CB
Quick Fuel SS-650 on my 306. It starts and runs perfectly. Not cheap but a very high quality product. You would not be disappointed with how it works.
I've posted this many times before. I suggest you use a double pumper. My experience with vacuum secondaries on these cars was not good.
· Junior Charter Member
I'm with Gordon. A 306 cannot handle more than 650 unless you're going to crank this thing, even then?
With a dual plane, do the DP and a 650. You could jet up a couple sizes (1 or 2) if needed but no need to get radical.
My 2 cents, just have some fun.
Thanks for all the advice guys. I bought a Holley 4150 - 650, DP.
