Help...Can someone that actualy owns a Canton
front sump 8" deep p/n 15660 please
tell me if this pan is going to protude below
the 4 " cross member.Thanks
Why don't you measure the depth of a stock oil pan and use that as a guideline ? The stocker sits just above the bottom of the 4" main tubes.
-SB
I have the front sump Canton pan, but I don't know the part number. With the Mustang convertible mounts, it does protrude below the frame by about 1/4" or so. Since the drain plug is on the back of the pan, not on the bottom, I'm not too concerned about it.
I'm using this pan. The bottom of the pan sits just above the bottom of the frame rails. There's about 1/2- 3/4" clearance. I have stock replacement poly mounts. Don't be afraid to use this pan.
Husband/Father/Son
I suggest the #15-694 . Canton built this with the Cobra kit car in mind. Stock pan is 7.75 deep, this one is only 7.50 deep. Clearance should not be an issue......I also suggest their matching oil pump part #M10833, and their dipstick kit, part #20-850
Just my two cents worth.
Bill S.
PS: I've used this on both of my 351W powered FFR's without any issues..........
