Received MK3 2/3/07
It came off the motor. 5.0 EFI
The one on the left is for the EGR valve and the other 2 are for you air pump. One is the TAB and the other one is the TAD. Used to control air from the airpump for emissions. HTH mike
TAB is the Thermoactor Air Bypass, the TAD is the Thermoactor Air Diverter. You also have the Vacuum regulator in the pic on the far right.
Received MK3 2/3/07
Thanks Mike
Gentlemen,
If you run without SMOG,Do you have to add resistors to fool the computer to preserve drivability?
Sten
