Unconventional Builder
I am pulling the top of the motor to do all of the gaskets and upon close inspection of the upper intake there is a crack in between the bolt hole and the body. It doesn't go all the way through. I am thinking of filling the crack with epoxy to keep it together until I upgrade the upper and lower and heads. No money for that now.
master craftsman
Aluminum? I believe tig should fix it, minimum charge from a welder $25 and your done.
section 8
I've had them welded , them touch it it up with a file then sandpaper. JB would be the 2nd choice Bob
