What is the best route to go to eliminate the rear axle c-clips? Is there a decent kit for this? I have been considering using 9" housing ends but don't know if I can use the ranger axles with this setup. Does anyone know if the bearing can be pressed onto the ranger axle or would 9" axles be required as well?
As Always, Thanks,
dug
Slacker Extraordinaire
Some spec racers use a c-clip eliminator, you might have better luck sking over there
No real reason for them and most road racing bodies do not like them. Drag racers do but if you have disc the axle is captive any way. Moser I think is the most common and who we deal with the most when we do discs for guys with C clip eliminators. HTH, Cheers Richard.
