1 - 3 of 3 Posts
I've read that the MkIII with 96-04 spindles would need a little bump steering adjustment.
The thread size on the inner tie rod is different than the ones supplied by FFR.
Is the taperred hole on the spindle the same for 93 and older as the 94 or 96 and newer spindles?
Then if the threads on the inner tie rod from FFR is the same as the Fox body tie rod, I should order a bump steering kit for a 93 or older?
I should have measured the difference between the stock 99-04 inner tie rods to the FFR tie rods. But I don't recall a big difference. Maybe a difference of 1 1/2-1 3/4".
Wow, I dont have an answer for you but this will bump your question back up.
just another builder
easy..call forte, tell him exactly what spindles and exactly what rack you have...done
1 - 3 of 3 Posts
