Just got the Fortes bump steer kit and wondering if anyone had a good setting for a starting point. I have 88 fox spindles and running +3 degree of caster, -1 degree camber with FR 18:1 rack mounted high with offset bushings. I have the bump steer kit mounted on the top side of the spindle steering yoke at present with no spacers.
Discussion Starter · #2 ·
ttt
Hi Todd,
Call me in the am and I'll e-mail you a picture of it installed.
Mike Forte
Vendor
Todd, it's really something that you have to measure as diferences in alignment, rack posistion, tie rod length all affect how much bumpsteer correction you need. Bumpsteer is the last adjustment to do in an alignment and you usually have to choose which range of motion you want to correct the bumpsteer in and whether you want bump in or bump out because you can't get rid of it all.
