1 - 3 of 3 Posts
I'm going to use '95 SN95 spindles, and was wondering if I have to drill out the taper on the spindle arm to use any of the available bump steer kits? I've seen some of the kits that mount the Heim end on the top of the spindle arm. Is a tapered spindle bolt supplied with this kit? Thanks in advance.
Just put a Breeze Bump Steer kit on Fox spindles, it came with a tapered spindle bolt & I didn't have to machine them. Give Mark @ Breeze a call, he can tell you real quick. A very easy installation, parts are top quality & good instructions. Good luck!
1 - 3 of 3 Posts
