Does a strip of this molding go across the top of the rear bulkhead of the passenger compartment? It seems that it should but my manual does not indicate this.
Does it also go across the top of the firewall?
I know , these are stupid last minute questions but the paint/body is almost done and I need to finish a few things first.
John:
The rear bulkhead does not get any bulb seal,even though it looks like it should.
Paul M.
Yes for firewall and foot box panel on driver's side (the little ear) and the panel on the passenger side you add in later (where the wire harness passes through).
No to the rear bulkhead. Do ensure the bulkhead is not touching the body with the body secured to the frame (trim as needed). Many people simply wrap the carpet over the top of the bulkhead panel...
HTH...
Thanks for the response.
Strange that the bulkhead does not get this.
I have the sound deadner and carpet up to the top but not past it.
I put it across mine anyway. (I figure it'll be a little more support for when miss Rhode Island sits on the rear deck in a parade.) :D
You end up seeing a little of it under the cockpit edge though.
c
