Status
Not open for further replies.
Just installed the breeze offset aluminum bushings the other day and was thinking Should the bushing end flat against the the rear of the steering rack..or should it be a little short in order to keep the rack from moving front to back.. Also I had to torque the steering rack a bit to get the bolt through the back hole..Is this going to be a problem..Thank you
[ September 07, 2002, 09:26 PM: Message edited by: Badcaiman ]
· Senior Charter Member
MINE SAME PROBLEM CALL MARK AND HAVE HIM SEND YOU A LONGER ONE IF YOU TIGHTEN UP THE ONE YOU HAVE IT WILL BEND THE EARS
Hello Tony J.. The bushing and the rack fit tight in the mounting ears..But the rear of the bushing doesn't come out flat against the rear of the rack..So the frame mounting ears are against the back of the rack..The mounting ears touch the bushing in the front and the steering rack in the rear..
In other words the bushing doesn't go all the way through the steering rack..Close maybe the thickness of a piece of paper short..The ears are not bending as they are clamping against the rack tight had to spread just to get the rack in..Do you still think I need to replace them ..
Thank you
no mark must have changed them after we noticed mine were short about 3/32 of a inch you will be ok
AS FAR AS GETTING THE BOLT IN ROUND OUT THE HOLES ON THE REAR I HAD THAT PROBLEM AND DIDNT WANT TO TAKE A CHANCE WITH STRESSING THE RACK
· Premium Member
The bushing is supposed to be short of the rack. You are mounting the rack and not the bushing. The rack has to be all the way back and against the frame or it would rattle. Cheers Richard.
Status
