That fitting is 3/8-24 to AN -3! Unless the Wilwood master has an AN inlet, you have the wrong fitting. The adapter you linked to is usually used for -3 AN braided lines. You put this on the end and retain it in a bracket...
I would check the Wilwood site for MC fitting info or call Mike Forte directly for the fittings/answer...
HTH...
Woops... :D
Glad you have them. Nothing like waiting on parts when you're itching to install something...
