I'm doing a non donor build (Breeze Smart-pak) and as I started on the brake lines I began to wonder (based on some things I've seen on this forum): are all the brake lines the same diameter?
section 8
they may supply lines that are all the same size . However way back in the 80's when I started doing this Saleen mustangs Svo mustangs and early 1989 MK7 lincoln with rear disc use a 1/4 " line ON the axle housing to go to the calipers . More volume is the answer if you need it I don't know.I run it on my mk 3 and it works great Bob
Most all-disc systems are 3/16-inch...
Rear drum and all drum cars usually had 1/4-inch to the drums...
HTH...
