Please respond if you utilized brake components from 1987 - 2000+ Mustangs. Recently I have experienced several scary braking incidents so I want to warn others and solicit feedback from anyone experiencing the same thing, particularly from those who have remedied this:
My setup is per the donor brake installation in the manual- SN95 Mustang GT PBR dual piston calipers and new stock pads/dics on the front. SN95 Mustang GT new stock rear calipers, discs and pads on the rear. SN95 Hydroboost (cut spring mod) and a FMS proportioning valve in the rear circuit adjusted to provide full pressure to the rear.
Under mild to moderate braking (which is 99% of the time), I don't notice any abnormal stopping. During "abnormal" braking (sudden or moderately hard braking, braking on damp roads, in turns, on sand or gravel covered roads) I have experienced three recent events that caused the front wheels to lock up unexpectedly resulting in loss of corning and steering ability.
Additionally, after inspecting the tread wear on the front tires, a pattern of angled wear on the ridges consistent with tire wear from heavy braking force is visible. The car is never raced and driven only as a pleasure vehicle.
Please chime in if you have a similar front brake over-bias situation and if you have remedied this.
