I am using the Vintage air ac unit from FFR. I would like to use Braided stainless lines with AN fittings. Does anyone have a parts list of fitting needed or can you suggest a brand to go with?
I don't have a parts list, but if you look at southern rod and custom, they have a full kit for a few hundered.
Here is some partial info. that may help. My system is supplied by Vintage Air. They supplied Aeroquip Braided Stainless lines with the system. Following is some part no.s. These may be vintage air though. You can call them at 508-867-6733 or 210-654-7171. (Can't remember which one worked so..try both)?
#6 Braided hose 36906-vur
#8 Braided hose 36908-vur
#10 Braided hose 36910-vur
#8 90 degree w/service port 36545-vur
#10 90 degree w/service port 36645-vur
#6 straight fitting 36440-vur
#8 straight fitting 36540-vur
#6 straight 90 degree fitting 36442-vur
#10 90 degree fitting 36642-vur
Of course your routing will depend on the fittings you use.
Summit also carries Aeroquip lines and fittings.
Hope that helps
Feng Shui Master
There is a place named "Gotta Show" that does SS lines.
