Looking for advice from those who have successfully aligned your doors with the body. I have been chasing my tail for the last few nights trying to get the doors aligned with the body. Here are some observations:
1. It appears that 6 of the 8 body bolts are too short, maybe need to be 1.5”- 1.75” long.
2. I can get most of the door edges to line up with the body but then the door latches will not line up or I can get the door to close beautifully but none of the edges are lined up. The rear edge droops when I open the door and would hit the body when closing if I did not lift up on the rear of the door. I don’t think that it is droop/ slop in the hinge.
3. The front edge (maybe ¼”) of the driver’s foot box can be seen when the body is mounted and screwed down.
4. The rear edge of the passenger’s door is right up against the body and I can’t adjust it away from the body. If I shim the latch then it sticks out but the rear edge is still up against the body.
Any help is appreciated.
Chris
Chris
