1 - 2 of 2 Posts
im building a engine to use a 174 root blower on , i was wondering what setup people were using on a 302 for a blower and whayt pistons,cam etc...
Here's mine.
FordmanDan creation, long rod 306:
Engine: 306ci (bore 4.030 x Stroke 3.00in)
Holley 4150DP 750cfm blower carb
Weiand roots 174ci, 6 psi pulley
LEVY race pan
12 lb alum. flywheel
Spec II kevlar clutch
Forged valve relief pistons
Scat rods 5.4” premium I beam w/ ARP hardware
Static Compression Ratio: 9.1:1
Dynamic Effective Compression Ratio: 6.9:1
Custom Grind Hyd. Roller for Roots Style Blower.
Duration @ .050” lift: Intake 224 / Exhaust 230
Valve Lift: Int.536” Exh.516”
AFR 185cc heads w/ 2.02 / 1.60 valves upgraded hardware (61cc*)
Crane Full Roller Aluminum 1.6 ratio
1 - 2 of 2 Posts
