1 - 1 of 1 Posts
BlackPath - 302 + 351W + 351C + 400M V-Belt Pulley Kit Fits Ford Engines (Polished) T6 Billet
Fits Ford 302, 351 Windsor, 351 Cleveland, and 400M. ONLY Fits Models With 4 Bolt Pulleys.
CNC machined from solid billet aluminum for light weight with exceptional strength; dresses up the engine bay by replacing the factory pulleys with beautiful and durable billet units
Includes 1x alternator pulley, 1x crankshaft pulley, 1x water pump pulley, installation hardware, and detailed instructions
CNC machined from aerospace-grade billet aluminum and anodized silver for maximum durability
Comes with detailed Installation Instructions. Fits small block applications only; 400M models must have a 4-bolt crank pulley and a drivers side water pump outlet
Small Block Engine V-Belt Pulley Kit
Brand New Ford Small Block Engine V-Belt Pulley Kit is designed specifically to reduce weight and increase horsepower. The BP 3 piece aluminum pulley set accomplishes this with minimal effort. The kit provides a 90% under driven ratio to maintain proper cooling and charging functions. CNC machined from solid billet aluminum for light weight with exceptional strength, anodized and polished for a stunning appearance. This set requires absolutely no maintenance once installed. Must be installed with the factory harmonic balancer.
Contents
  • (1x) Alternator Pulley
  • (1x) Crankshaft Pulley
  • (1x) Water Pump Pulley
  • Hardware
  • Installation Notes
Compatibility
1969+ Ford Small Block Engines: 302, 351 Windsor / 351 Cleveland, 400M
1969+ Ford Passenger Cars
This kit sells on Amazon for $147 USD. I am reselling this (new and unused) for $90USD plus shipping from Vancouver Canada.
Automotive tire Font Rim Auto part Circle
1 - 1 of 1 Posts
