I see the caption under the oil pump says "Livernois Motorsports supplied a set of billet oil pump gears to replace the weak stockers. A new, Mustang oil pump is required on an F-150 engine."
I bought a billet oil pump gear for my build but didn't realize the pumps or pump housings were different. Anything you can point me to?
I just did some checking. That applies to the 2011-2014 F-150s but thankfully Ford started using the same Mustang GT oil pump on the 2015+ F-150s (which is what I have).
Now back to your build and hopefully some insane dyno results
Greetings and welcome to the adventure of my first build. This will be my build blog and will be mirrored on my Facebook page, Wilson Cobra Build. 3 years ago I decided to build a Roadster, and eventually narrowed it down to Factory Five’s Mk4 Roadster and a 2015 Mustang Donor. I will repost my...
I plan on running A/C in my MK4. The engine is a 2001 4.6L 2V out of a Mustang GT. The FFR headers hit the back of the stock A/C compressor. As it bolts directly to the block, I'm not sure of a solution to this problem. Is there another compressor that will bolt into the stock location that is...
Hello everyone. I am looking for recommendations for shorty headers for 2002 4.6 SOHC. I need to run cats, so shorty headers with catted J pipes are my only option. I tried BBK Equal Length Shorty Headers last year, but when I swapped them side to side and turned them around, they would not...
Next story will show exactly how we got to 609, though it's teased at the end. Made 592hp with a stock engine with camshafts, cold air intake, long tube headers, and an E85 tune. I validated COMP's 2018 cams. They actually held off production on them until I completed my testing, haha...
I am performing a Lund tune on my MK4 Coyote build. I have a 2017 Gen2 Coyote crate motor, FFR headers/side pipes, and TKO 600 transmission. My tuner never mentioned any issue with knock on my data logs until my R3 WOT data log session.
For my R2 (second revision) I performed a WOT from 2500 -...
