.......between the header and side pipe?
I have 14 miles on the go-cart and have already go a leak, here.
Ideas? Any copper ones out there?
td
Super Moderator
TD-
Most SB and BB guys are using Permatex hi-temp copper silicone. Just lay a nice thick bead on the joint, tighten it up, and away you go. Mine has 4500 miles on no leaks so far.
2FAST
Wow, that's easy!! I can't believe that stuff will take the heat.
I had visions of attempting to cut copper ones.
Thanks, 2FAST !
Thanks, Wade !
td
1000 miles and no issues.....
Tommy,
I ordered a new set last week from Mike.
I will use Permatex hi-temp copper silicone and INOX bolts...
I think that an antiseize is a good option and do not ask me why... ;)
Good luck
Cyril
Hi Tommy,
I make gaskets for the 4X4 collectors. Call me if you need them
Mike Forte
