1 - 15 of 15 Posts
Anyone come up with a good, cheap idea for a trim piece for the opening where the steering shaft comes through the dash?
I honestly can't remember where I got mine but I think it was from Mike's
If you just have a round hole through the dash cover material, you can go to Lowes or Sears Hardware and get a large zinc plated washer. It might not be the prettiest, but it will serve the pupose. Cost about $1.50. If you want something like the cool one Todd shows above, a couple of the vendors have them.
I've seen people use chrome sink pipes. Get them at the plumbing section at Lowes Cut them to size. The flare at the end covers the dash hole.
The above solution on the raw dashboard looks real pretty. HOWEVER when you click on the link and see it installed on a car with a rusty old steering shaft it looks god awful. You either need a black/chrome finished steering column or else a different bezal.
I think finishline sells their roll bar grommets one at a time for this purpose -- that way you get the nice chrome trim with a rubber boot to hide the unsightly.
-SB
I went to Lowes , and bought a 1/8 inch x 2 inch piece of flat....cut out the bezel and center area , and drilled evenly spaced holes (6) around the edge (counter sunk)...Polished the bezel on a wheel on the drill press , and mounted over the dash hole with flat head stainless phillips screws...looks great, and cost almost nothing.
Finish Line (a vendor on this forum) has a great looking round bezel for $20.00 part number "SC-Bezel" that I use.
Don
Well Bow Tie Boy ya just have to be a little quicker than us Blue Oval Boys, you know what they say about Ford --- First-On-Race-Day :D I just noticed the plack on the dash I got for you, looks good. You did a great job on your build Jim.
PS I just got to my 1000th post with this one :cool:
Don
-SB
I'm with ya. I used a piece of the corrugated plastic wire loom that fit perfectly over the shaft.
Supermoderator
Mike's Custom Parts sells the oval shaped bezel, and a little elbow grease and paint on the exposed shaft works great.
On the photo I posted as well as ZL-1 we used the Finish Line part number "SC-Bezel" in conjunction with Russ Thompsons turn signal setup so you don't see any shaft at all and the ring with the rubber grommit fit perfectly together.
Don
Discussion Starter #14
Thanks for all of the replys. I'll probably try to polish some aluminum up and make my own.
1 - 15 of 15 Posts
