1 - 18 of 18 Posts
I've got the harness out of my '87 donor car and I'm a little aprehensive about puling this one apart. I did it once befor on another car and did't really enjoy it. Besides I'd rather spend time on the body and engine.
I'm considering either having the harness dieted by someone else or going with an aftermarket harness but I want to stick with the stock FI system.
We're looking for good quality and moderate cost.
Any Suggestions would be much appreciated.
I SENT MINE TO RON WEATHERBY AND IT CAME BACK WITH EACH WIRE LABELED AND ALL I HAD TO DO WAS LAY IT OUT ON THE CAR AND HOOK IT UP PIECE OF CAKE.
I Squared by all means
I^2
I purchased a Painless harness, and ended up taking it all apart because I didn't like the way they grouped the wires. I definetely would not go that way again.
its Rob wetherby and I do not believe he is doing it anymore. I squared or wirediets.com (rodger stein) or painless and tackle it yourself....
I Squared.
Roger Stein at wirediet.com is doing mine.
Paul
Go with I Squared. They are a forum advertiser, and they make a slick product.
Anoter vote for Roger Stein. Clean and labeled and money well spent. Calhusker
Well I had always thought I would just go with a Stein Wire Diet, but after checking pricing I think I've changed my mind..
Stein Wire Diet for a 5.0 based build - $500
I-Squared 1+1 Million System - $554.95
Just so we're fair here, the Wire Diet is pretty much a plug and play deal, but the I-Squared does still require wiring stuff up.. Correct?
And the I-Squared does still cost $54.95 more than the Wire Diet, but it gives nice LED diagnostic indications on circuits, cuts down on the total amount of wiring, is relatively simple to install and all wiring except for the engine harness will be brand new.
Is that pretty much it in a nut shell?
What I'll probably end up doing is, trying to do my own wire diet and after spending weeks pulling my hair out I'll give up and then order the I-Squared system..
Roger Stein is doin' mine!
Roger did mine, plugged it in and off I went. Make sure you specify what you are or are not doing. IE: trans harness, with or with out emmissions etc. It is a beautiful thing.Mark
1 - 18 of 18 Posts
