1 - 10 of 10 Posts
I need to pull a pilot bearing out of a 302 in order to mate it to an automatic transmission.
What is the best way to go about attempting to knock the pilot bearing out??
So far i havent had any luck trying to wedge it out with a flat head and a hammer.
Thanks!
Fill the hole with grease, insert a close fitting punch or similar rod (old input shaft works well) and hit it with a hammer.
Hydraulic force on grease will drive bearing out.
Works like a charm.
Sean
Autozone has a loaner tool just for this.
the grease will work and autozone has the tool. I bought one about 10 years ago because i needed it to take one out of my mustang. But I can`t remember where I bought it from.
what about a plastic input shaft
Thanks for the advise everyone!!! I have pretty much destroyed the edges of the chinese pilot bearing trying to get it out with the screwdriver.
This forum is priceless!!!
That's what I used the last time I did one. Actually, it was one of those clutch disc alignment things. Packed the bearing with grease, and hit the alignment tool a couple of times with a BFH. The bearing popped right out.
1 - 10 of 10 Posts
