1 - 13 of 13 Posts
After 2,000 miles on my 2.73's, I'm ready to get some 3.55's.
My neighbor(Transmission/Driveline specialist) will do the set-up/install but I will supply the gears.
Where to buy?? Want good quality with decent price.
Thanks in advance...
Eric
section 8
Good quality ,Ford Racing always had good luck with them also Richmond do,nt forget the posi lube may want to rebuild the posi while your at it the kit is cheap and you have it out and you have a specialist at hand. Bob
In doing research on a TracLoc rebuild I came across some info on gears.Apparantly the Ford gears are marked on the pinion referring to the needed pinion shim.They group the production runs by measuring in a fixture and marking them w/ something like a +,a - or a 0. So you compare the mark on the old pinion w/ the one on the new pinion and then can calculate the needed shim.For me anyway,that says buy Ford and forget the rest.
Mike Forte....great prices and a great guy, when he's not sleeping!!
Eric:
Whatever you do ,just make sure you get Ford gears.
Paul M.
Just did that swap myself, I bought used gears off of Ebay (MISTAKE - I found the patterns hard to read, and I know it will nag at the back of my mind). As long as you're back there, might as well replace all of the bearings & seals - the master rebuild kit was about $110, the posi rebuild kit was about $50... seemed like false economy not to freshen everything.
In my case neither the original or replacement gear was legibly stamped with a relative pinion depth index (+3 -2 etc.), although both were Ford gears. Most "swap instructions" on the net do recommend sticking with Ford gears, I'd second the recommendation based upon my experience.
Doing it again, I would buy new gears from a forum vendor.
Max at Five Star Ford. Quick and easy.
Discussion Starter · #11 ·
Thanks guys,
I'll get the FRP gears. Rebuild Trac Loc and bearings are a given(while it's apart).
Eric
1 - 13 of 13 Posts
