1 - 3 of 3 Posts
# 5014 fired to life fri afternoon for the first time. It's stock carbed 302 w/ 90' doner trans w/ new cobra clutch, pilot and release bearing. Went gocarting sat morning and what a blast, however there is a knocking sound coming from the bellhousing area. It is in time with engine rpm. seems to do it more in first gear. any suggestions before i pull motor and trans to double check things? maybe its allways there but I hear it because no body, insulation...???
Something's not right, for sure.
Did you put the dowel pins in the flywheel or make sure they're there?
You shouldn't hear anything from inside the bellhousing.
1 - 3 of 3 Posts
