A few weeks ago stoped by the Factory and noticed that the Bell Housing was atleast 2" below the 4" frame rail. My question is this common when using the stock Bell Housing? Is there a smaller after martket one?
Super Moderator
You will have to cut the bottom flange off parrallel to the ground
The stock bellhousing is pretty flush, as I recall. You have to cut part of the flange off aftermarket scattershields like the McLeod, though.
forrest
I believe the stock bellhousing does not sit below the frame rails, at least mine doesn't. Aftermarket ones do sit below and should be trimmed. No big deal to do.
FFR2625
A sawz-all will cut thru that in about 5 minutes. However, its a bunch easier when its off the engine, unless you have a lift.
