yesterday I was celebrating our longer than normal summer with a cruise to the ocean when suddenly I hear a click click click-thought it was a exhaust header bolt worked loose for the first time in 12,000 miles (I have Percy's bolts) closer inspection revealed the BBK headers cracked at the block flange at number ! cylinder-the crack is a jagged pattern around the whole circumference, couldn't find this on my search of the forum posts-has this happened to anyone? do I have it tig welded-covered under replacement? bummer!
Are you using the rear Side Pipe Hangers?
Jack
