A friend and I designed and built this box. I bought a cheap metal brake in April. This is the first "real project" for our metal brake. It is also the first shot at the box(NO DO OVERS) :D Pretty good for beginners! The trunk metal is also done! Time to fit the body, I guess?
Thanx for looking!
Tony
The Greek
Very nice work!!!
Looks good. I've been thinking about something like that. What size battery did you end up choosing and did you rivet the sides?
I can't tell if you have some in the one side or not, but you might consider some vent holes. It is critical that gases from the battery can escape.
looks great
That is a great job for the first project!
Paul M.
I would suggest that you add some 3/16" rivets inside the box into the 3/4" tubes. You will need a right angle drill but it makes the box much more rigid in between the 3/4" tubes.
