Where do the copper washers on the banjo bolts go? On top next to the flange, on the bottom next to the caliper? Both places? Are the washers a "one time only" kind of part or are "took 'em off the mustang" ones ok?
Thanks.
Regards,
russ
They go on both sides of the block, under it next to the caliper and over it under the bolt head. If you can replace them. They are generally not damaged and we have reused them in the past but they are not expensive so get new if you can. HTH, Cheers Richard.
