Professional Internet Browser
Water pump on the new engine leaks as fast as I can pour water in. Tried 3 sets of new gaskets, no luck. I am going to leave the car at home and not push my luck trying to drive it to the open house.
Maybe next year if we still have it.
Ditto on the timing cover. I built my first 302 at age 16 and put the wrong bolts on the back side of the water pump (the correct ones had very thin heads). When I bolted on the pump it cracked the front cover. Water just poured out like crazy.
Not a dig at you here but you might think about just taking the thing to a mechanic. Sometimes I've been stymied and frustrated by a car and finally just took it to a pro. A fresh look at things often finds very simple problems that we overlook. Forest for the trees and all.
Yeah, those two thin-head bolts on the bottom backside of the pump that connect the plate to the pump need to be tight and out of the way of the timing cover. I forgot to tighten those when I put a new standard rotation pump on my 302. They can just barely be reached with a real flat wrench.
Aaron,
It is a very common mistake, mis-matching the water pump to the timing case cover. Damn...done it more than once too!
If it's coming out as fast as you indicate, not likely a gasket.
When you get the pump apart take your gasket and match it to the pump, then the cover. Bet if you look close you will find a 1/4 gap at the bottom of one of the case ports.
DV....this too will pass ....get that puppy to the Fling!
I think there has to be about a dozen different variations and combinations of gaskets made for the SBF water pumps..
Sorry to hear of the problems Aaron.. :(
It should have worked, it was the pump off the old engine. Both timing covers were to my knowledge 87-93 sbf HO 5 liter covers. Oh well I was obviously working wayyy too fast and stressing out and couldn't do it right. Maybe next time. Off to the open house now (in a honda for good gas mileage hehe).
